P
Pepsi
I am a newly Qualified Sparky and have recently been asked to get power to a garage. After looking at the job realised that there has been power to the garage previously as all the previous wiring has been left it but has no power.
from what i have heard the house had a re-wire(dont if it was a full re-wire or a part re-wire) and the feed to the left in in the gagrage side and goes through a conduit which i presume goes under the house and into ccu, but i cant see the wire at the ccu.
there is a spare 32ma RCBO at main ccu.
wanted to know if i could use the conduit (if it goes through from ccu to garage) with 10mm TandE and use the existing wiring left before?? or do i need to go under the ground and use SWA?
any help would be appreciated
