P
Pepsi
I am a newly Qualified Sparky and have recently been asked to get power to a garage. After looking at the job realised that there has been power to the garage previously as all the previous wiring has been left it but has no power.
from what i have heard the house had a re-wire(dont if it was a full re-wire or a part re-wire) and the feed to the left in in the gagrage side and goes through a conduit which i presume goes under the house and into ccu, but i cant see the wire at the ccu.
there is a spare 32ma RCBO at main ccu.
wanted to know if i could use the conduit (if it goes through from ccu to garage) with 10mm TandE and use the existing wiring left before?? or do i need to go under the ground and use SWA?
any help would be appreciated
You must have tried a draw wire through the conduit already have you?
My concern would be the burial depth of the conduit, is it likely to be damaged by any future digging, excavation works.
If you can get a draw wire through the conduit, why dont you just use armoured cable?
When you say newly qualified do you mean apprenticeship is 4 week cowboy course?
It's your call mate, SWA is always better then twin in pipe. Like the last guy said if someone sticks shovel through then it could come back to you.
What's going in the garge? Just a few sockets and some lights?
Or is there a high demand as your thinking 10mm
so if its a newish rewire all bonding is in place?
the conduit goes under the house and no getting under there. im going to try the draw wire now. going up to try get it sorted. Could use SWA but the really want to take up all the ground as they just recently had it all done,
the cable that feeds the garage is probably pushed back in the wall behind cu.. you could test the cable and see if is ok and assess if could be damage in future. you may forget about 10mm if 20mm conduit.
Is the garage a long way from the house? Unless it is 10mm sounds big to me. What's the likely load? If you have just qualified you should know how to work all this stuff out.
he is an apprentice jumping in to quick... i thinks.. weve all been there, wel i have and them days were stressful and costly...
If you don't know where the conduit ends how on earth do you expect to use a draw wire/cord??
stick a walkie talkie with tape on the button and listen for dink dink dink at pushing end or get homeowner to listen
Obviously your part p registered to carry out the work then, but then if you was part p you wouldn't be asking this question.
Don't bother with t&e even though its in conduit just won't last the time, swa every time if the customer doesn't want it don't do it, it's your name on the work, I usually run 4-6mm for a garage depending on sockets etc plus allow for future works in garden etc
Currently have 2 flood lights one with a sensor. 2 or 3 lights. 4 sockets. Previous owner had used the garage as a workshop/car repair garage as there was a pit in the floor.
After a proper inspection the pipe i thought was conduit was infact a copper pipe which i.could see between the garage and raised patio. Under the floor boards i don't know what there assuming just fed under floor boards(in the.house) and drilled straight through the wall of the garage and wire straight through garage wall; with old wiring still intact.
tried pulling out the old wiring but couldn't. So Im guessing the only way is SWA. Round the front of the house under pebble drive.
Is there any other way i could do this? Like running a wire round the exterior of the house? Is it even possible?
