J
JamesG17333
Hi,
I am installing an outside socket but had a question about how I can connect it to the internal supply. I have tried to represent my options/plan in the attached image. Are there issues with either of these approaches?
Additionally, does this work need to be approved/signed off in anyway or can it be done as a DIY job?
scrub top pic. that's for wimps.
you don't need a FCU as long as the internal socket is not a spur, and there's only 1 outside socket (single or double). it also only needs to be an RCD socket if the house ring final is not RCD protected in itself. a Minor Works Cert. is desirable, but it's not notifiable work under part pee.
Also what cable are you taking to your socket? Pic says "swa 2.5mm2 t/e" which are two different cables? Needs to be 2.5mm 3core swa scrub the t/e bit
How the frig are you going to terminate that swa cable?
I’m not even sure you need swa
Take the spur cable straight outside fit a IP rated SFS nd take the SWA to the ip rated twin socket, gland into the spur and the twin socket
Sorry Pete
I can’t understand how the swa is going to be terminated in too the plastic outside socket and the switch fused spur, and still have fault protection with the armour ?
And why is a switch fused spur even needed.
And why swa?
Sorry Pete
And why swa?
outside socket remote from house, ergo... SWA. what's the problem with terminating i a IP65 socket box?
Thanks. Although for wimps :-) is it viable? Allows me to plug and unplug as needed and not mess with a spur off the socket which is a little way from the wall.
I am actually looking to do this in two different places so may do a different approach in each based on use case.
so, if on a plug top, you'd not fix T/E into a plug top, would you. if you did i'd come all the way down to that den of iniquity (london) and spank your arse.
JamesG17333,
Deleted member 109422,
