Currently reading:
Consumer Unit Change
Discuss Consumer Unit Change in the UK Electrical Forum area at ElectriciansForums.net
Nickj
Hi All,
I am tomorrow going to be changing a consumer unit ahead of my Elecsa assessment next week.
Just wanted to check that I'm not missing anything with regards to amendment 3.
I'm going to be using a BG consumer unit supplied with RCBOs.
It has a cut out at back for cable entry and so I am going to pass all cables through that using a grommet strip around the metal edges. Do I need to seal the entry hole? I believe not however I have heard arguments that it needs to be sealed. Passing all cables through the rear entry may require de-rating cables due to grouping however the cables enter the current board (3036's) through the rear. Can i therefore assume ratings are fine?
I am going to attach the consumer unit to the wall using dewalt wall dogs which require no anchor in wall meaning I don't have to worry about plastic wall plugs falling out in the event of a fire.
If the cables are too short (I sincerely hope they won't be) I'll use an adaptable box above the board to mount a din rail to extend wiring. Does this adaptable box need to be non-combustible too? (associated switch gear covers this possibly?)
Thanks in advance
Nick
From the point of view of the assessor, if he asks about this, you have cogent and reasoned statements indicating that you had considered the issues and decided that the situation was safe and compliant with BS7671 as far as you understand it.
If you can state this with the assessor at the time and therefore show that you are competent then this should be acceptable.
If the assessor still decides that rectification is necessary then, because you are already demonstrating competence, a simple photographic resolution should be sufficient.
That's what I said, lie through one's teeth :eek:
I am assuming there will be some spare ways at the new board. How do you intend to fill them, I always stick a breaker in them much better than blanks which the assessor may not like.
There are spare ways and I have filled them with blanks.
I did consider this carefully and thought about spare breakers, those new dummy breakers and blanks.
I decided that I'd follow manufacturers instructions and inside the box there were blanks to be used to fill spare ways.
Blanks fit into the board snugly and whilst they could be removed it wouldn't be accidentally as you do need to manipulate them a little to get them out.
Bs7671 does say to follow manufacturers instructions and so if there is an issue with these surely it's for the manufacturer to answer?
This board is mounted high enough to stop children playing but low enough for an adult to operate it at arms reach.
Overall I am happy with this choice...
What make is the board ?
Some push in blanks may comply and some may not. I always use dinrail mounted blanks to ensure a good secure hold and compliance.
I recently used used a BG garage board that was supplied with push in blanks. They could be flicked out easily with a fingernail, so not compliant, no matter what the instructions said.
BS7671 asks that products are selected for their suitability and compliance so the onus is on the designer/installer.
It's a bg board. I've tried to remove them and whilst I could it took a fair bit of wrangling to do it. Switching over to blank mcbs wouldn't be much of a task.
I'm guessing any make blank would fit? The bg ones aren't in stock and so I couldn't get them in time.
These MK ones are in stock and I could put them in tomorrow http://www.NoLinkingToThis/p/mk-blank-mcb-pack-of-5/71995#product_additional_details_container.
If nothing else it would be something to talk to him about and distract him from the main earth
No idea if the MK blanks would fit. I tried Hager blanks and although they provided an IP2X fit, they didn't really fit and I wasn't happy with it. I ended up buying more mcbs to plug the gap.
Oh common, last time I tried removing CU push in blank covers, I broke my precious finger nails :). Din rail ones are better, but you still need a tool with the former.
Anyways, give this bloke a break. ''Don't have nightmares, do sleep well",
I held this opinion until I tried the metal clad BG garage board recently. Most push in blanks are very solid.
You can't sweepingly approve or disapprove any type of product though, especially when it comes to BG. They really do only take a stern look to make them fall out.
A modular DIN rail blank of fit a breaker. The only cover blank worth their salt are the twist fit ones which cannot be removed with the cover in place.
I use the Wylex metal blanks - they can only be fitted before the cover is fitted. And I fit them to other makes of CU
Trouble is then you need to bond them. Daz. (popcorn ready).
Ok I'll bite... As long as the metal enclosure has exposed metal at the rear of that blanks connection won't it be bonded via that?
And if it does need a bonding cable will 10mm be enough :)
Brass nut and bolt with flylead to earth bar. Daz
10mm or go the whole hog and make it 16mm? after all it could contact a pretty serious bus bar...
Hi all,
I've fitted the mk blank mcbs. They look ok (not as neat as the plastic blanks in my humble opinion).
Just to clarify one point.
They fit neatly but I would say just about fall short of ip4x. I am correct in thinking for the mcbs and main switch I only need ip2x? (I'm way above ip2x, close to ip4x).
Thanks all for your help, tomorrow is the day and so I'm pretty much out of time :(
Only the top is ip2x the rest is ip4x
Sorry yes the other way round.
Only the top is ip4x the rest is ip2x
My bad :)
These are the blanks I was referring to didn't realise Wylex now do them in metal, normally fill spares with mcbs. So this begs the question are plastic blanks still acceptable with the metal enclosure.
Thanks all, I'll post tomorrow to let you know how it goes.
Plastic blank mcbs meet all requirements. Let's not forget the mcbs themselves are plastic.
The plastic blanks I can see being an issue as they can be removed without the use of a tool to varying degrees, some are great but really the ones I had could be removed with some wrangling.
The plastic blank mcbs cannot be removed without a tool amd therefore are entirely up to the job.
The reason I didn't use the metal ones are for the reasons discussed above. The board is painted and so they wouldn't have been earthed.
Chances of a cable coming into contact with them is slim but still a chance I guess.
Feeling absolutely fine with the blank mcbs :)
Don't sweat it. Worst case he makes a comment and you discuss it.
Reply to Consumer Unit Change in the UK Electrical Forum area at ElectriciansForums.net
