G
georges
evening everyone been to look at a fire in consumer unit today. tn-c-s supply property has economy seven as well.
fire was behind main switch were they were joined then to a henley and then poorly installed isolators to another set of consumer units at the back of the house which was extended about 5 years ago the feed to these is 10mm twin and earth from the henley blocks. no certificates it looks as the economy 7 board was extened the same way but you cant remove the cover of this as the kitchen unit is built across this.
this is the best bit after some conversation with the owner he is a local building inspector.
I am looking at fitting new tails to external meter box threw cavity in trunking and new board .repair ring and lighting cable as insulation test is 0.001 found to were cables damaged.
any thoughts greatly appreciated
