Discuss Consumer unit running from spur for pond stuff in the UK Electrical Forum area at ElectriciansForums.net
J
jonboy79
Hi all,
So i was thinking about running a consumer unit from a spur for all the outdoor pond stuff. I wanted to have in there 3 Rcbo's at 6 amp, 1 for the pump, 1 for the led lighting and another for a water feature. None of these go past the 6 amps. They will only be used for this and nothing else, and wanted them to be protected and isolated with there own tripper, so say the lights go, the pump won't etc. The CU has about 10 feet to where i will be picking up the power. Will this be ok??
Many thanks
PS was going to run, spur > RCD > extension lead. But couldn't find anything that would be a mcb, unless you know of anything like a plug in rcd which is a mcb. I know the CU option is not the cheapest way, but also gives me a little project on the way..
Where exactly are you spurring from? Also this is notifiable work.
Thanks for the quick reply. From the ring that does the down stairs plugs i assume, it is a plug next to the down stairs toilets. I guess it's notifiable due to it being a outside circuit, but would a extension lead permanently fixed also be notifiable??
would a RCD plug in adaptor, plugged into your ring, which has an extension lead plugged in that, which would be protected by a 13A fuse not be acceptable? (that is a question aimed at someone who will correct me) do you know the current requirements of what you intend to power?
Yeah this was my standard option but like the idea of a mcb, as a rcd protects for earth leakage but would like something that protects the circuits of the water feature as it's got a pump and also some led circuitry lighting, and can't get into it if it goes wrong.
Cheers
ps will a low amp fuse be just as good?
Cheers
Ordinary 3A plugtop fuses would probably do.
By the way, is your socket circuit already protected by an RCD in the consumer unit or elsewhere?
Reply to Consumer unit running from spur for pond stuff in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
I have a fairly recently installed consumer unit with an RCD, between it and the garden there is another, much older (25yrs?) RCB (big Wylex...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
DIYer question. I have a 32 amp supply going from consumer unit in garage to kitchen. It supplies an induction hob only. The cable is easily...
