Discuss Consumer unit: which comes first? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
greetings.
Just a quick question about switch order.
Should the main circuit breaker be wired in first before the main switch, or is the main switch always first in line from the supply feed?
Thanks,
Gary
greetings.
Thanks,
Gary
Gary
Hi you don't tell us what you are in your profile, by that I mean: Electrician, Domestic Installer, Apprentice, Trainee or DIYer in order to tailor replies we need to know at what level you are.
With such a worrying opening question I don't have much hope for this thread.
I tend to agree, but patience is a virtue, lets just wait and see what the OP's experiences are, could be just staring out. On the other hand could be a complete Gimboid.
Apologies for not providing more info.
Have no fear, I am certainly not a cowboy when it comes to electricity!
In fact, I'm only just into my second year studying to be a domestic electrical installer, then planning on moving up to commercial/industrial.
I'm asking this as after having attended my first practical week, there was some discussion about the correct order that switches in the CU should be wired in.
In my understanding, the feed from the supply comes in to the main switch, and then to the circuit breakers for each circuit in the installation, yes?
Some folk attending were questioning if there should be an initial circuit breaker before the individual ones controlling the circuits.
I just thought I'd throw the question out there...
think OP is thinking of dual RCD board, where it's main switch - RCD - circuit breakers.. and wondering whether the RCD should come before or after the main switch. the answer is always main switch first. no matter what the board configuration is after.
Main Switch is there to Isolate the rest of the installation. As has been said Main switch first, then the individual circuit breakers.
Corrected that for you.
Many installations have 2 or more fuse boards .....
Sorry Murdoch, my post mentioned Main Switch to isolate the rest of the circuits connected to this fuse board, 1 fuse board 1 main switch, no mention of another fuse board, if the installation had more than 1 fuse board then the same would apply to each fuse board, can't see how you corrected it for me.
JW usually has a good explanation on all thing electrical
Reply to Consumer unit: which comes first? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Can you feed a consumer unit from another consumer unit, It would be supplied by a non RDC protected MCB. Is this allowed as I have always seen...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
