Discuss Contactors : and how they work in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes Luke, this is done as well.
I have used large contactors where there are fixed terminals for the neutral in and out, or an additional set of contacts for the neutral
The contactor you have shown is 3 pole, so could be used for three phase (L1, L2 and L3)
or single phase using two of the three contacts to switch line and neutral
- i dont know if you are aware, but a lot of industrial three phase systems (particularly those supplying motors) dont use the neutral anyway!
Reply to Contactors : and how they work in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
We are a UK registered Electrical company with a large contract based in and around Toronto, Canada. Are you looking for work? We have a...
Electrician Jobs EC Qualifier United States
We are an established electrical contractor. We are looking for Journeyman Electricians or Residential Wiremen (if you are only doing residential...
