M
mally4601
hi guys ive my 2392 test tomorrow , ive a few thing to ask to be 100 per cent about all
continuity of 2 way lighting circuit , at the celing rose do i test between live and earth or switch wire and earth and then turn switches on and off , do i need to open the switches to check between live and earth
final ring circuit is it the highest reading between live and earth from the sockets if a radial is spured off it, then would i take the highest reading from it .
insulation resistance , do i have to test each circuit cause theres a rcd on or can i test as whole , also for the ring circuit do i put L-L N-N E-E in connectors then do insulation test
prospective fault current , do i connect earth clip to netural bar then neutral to neurtal , then live to live , pscc , then E-E N-N L-L pefc take the higest reading
ps if ive missed any thing out feel free to comment
