Discuss Converting 3 gang to dimmable without chasing for bigger back box in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Just seeing if anyone found manufacturer or a solution to avoid chasing out for bigger back box if converting lights to dimmable or just converting one switch to dimmable as all types found require bigger back box. Have looked into grid switch systems but these still seem to require a double back box? Cheers
Mk dimmers used to come with a spacer ...
jus chop out a new box , takes 15mins with an old wood chisel
Thanks chaps but your all off the mark i might not of made self clear 3 gang dimmers require a double back box am looking for any products or solutions that have 3 dimmers that fit the width of a single back box so can avoid chasing out
Reply to Converting 3 gang to dimmable without chasing for bigger back box in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi all, I am an experienced DIY electrician and I just wanted to ask a quick question about something since I am new to this forum, if it hasn’t...
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
I'm just wondering if anyone knows whether any/all of the Quinetic grid switch modules fit in a 25mm back box? It "looks" just about ok. But if...
