Discuss Cooker circuit options in the UK Electrical Forum area at ElectriciansForums.net
induction hob and oven have arrived onsite and both suggest a 13amp supply is suffice.
The oven I can believe, mine is 2.8kW so would be OK on a 16A RCBO. But a typical 4 ring induction hob is around 7.5kW so a 13A plug seems highly optimistic and needs careful checking.
I've installed plenty of induction hobs that come fitted with a 13A plug from the manufacturers. Seems pretty commonplace with them now.
Any modification to the original design " can " void warrantty,
that includes chopping off plugs.
Check with any lawyer they will confirm it.
Remember the law has nothing to do with common sense.
it is as it is !
If the cooking appliances do not come with plug tops, then the manufactures or consumers supply lead would/should be suitably rated, to carry the maximum fixed load of said appliance.
if they don't come with plug tops, then you'll get a nasty belt off the exposed live parts in the plug.
Fair play this thread is hilarious, I can't remember the last time I gave 3 funnys in one thread, keep up the good work pmsl, oh by the way Bruce, it is different up here in the modern world than down under :D
32A RCBO, 6mm cable, single socket or preferably FCU with 13A fuse no problem at all?
In fact with that load a 1.5mm cable would be ample, as long as adiabatic checks out on the prospective short circuit current.
Reply to Cooker circuit options in the UK Electrical Forum area at ElectriciansForums.net
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
Evening all, I'm upgrading my kitchen electrics replacing the current gas hob for an induction hob. The oven was previously plugged into the...
