M
Morty
Alright guys, I did a kitchen where they asked for a cooker supply to which I intstalled for them. But when I went back for the 2nd fix the cooker they had bought was only a small one which came with it's own kind of kettle lead that you plug straight into the back of it.
So with the 6mm tail coming from the isolator I just put a socket on it and wired the lead into a 3 pin plug and plugged it straight in. But the customer questioned it because he came across a note in the manual that said: Uk and Australia only - Do not use 13 amp socket to wire in cooker.
The cooker was rated at 3250kW and the isolator was fed from a 32A fuse, so once diversity is applied it comes in at less than 13 amps. I can't see the problem with it so I just assured him it would be ok.
What do you guy's think about it?
