Re: Correct warning signs for high voltage (potential belt off 2 phases) please help!
Fair point. I always took nominal voltage to be to earth, but after looking at the definitions in part 2 of 7671, it doesn't specify, it says that it is the voltage by which an installation or part of one is designated.
No worries evryday a school day even ive been corrected today and ive been in the trade 25yrs lol
voltage (potential belt off 2 phases) please help!!!
Expected voltage in electrical enclosures is 230v where you exceed this then a 400v warning should e affixed, also when you say cab what do you mean? ... Electrical enclosure? How exactly would someone come into contact with both phases (i assume they are over different phases... your opening post has me questioning myself)... if they require a tool or key etc to gain access then they should be competent to be working on 3ph if they can gain access without a tool then an overview of the safety of the set-up will be needed to address this.
I'm betting a server cab...or rack...
Equipment inside fed from 2 different phases. It is normal practice to label it up as 400v, usually on the job spec actually. There normally under most circumstances kept at 230v.
So just ops teams opening it up not electricans.
Although he could be on about something totally different LOL...
More than likely if it is fed from 2 different phases it will also be from 2 different supplies. This would also require a label.
Now that sounds more like it for the UK!! I'm sure many can think of umpteen labels that can be applied to this panel, going by the amount of labels that seem to get plastered over every CU these days!! lol!!
