Discuss CU Max Height According to Building Regs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
off top of my head;1.this isnt domestic so heights dont count
2 .could someone say above a door where people are going through is not reasonable access for maintenance /inspection?
"new circuits and new extensions do NOT need to conform
The approved documents to both Part M and Part P expressly say that; it is quite acceptable to mount them at a height inkeeping with the existing property"
Desperately trying to find this quote where exactly can i find it in the appeoved documents?
Any help would be much appreciated,
will have a look tommorrow matey, aint got it in front of me
when i had my nic assesment the assesor asked a few questions on this, i replied by saying all the standard height things should be at etc. he pointed out that if the customer states that they dont want consumers at certain heights as well as switches and sockets etc, that you dont have to fit them at this height. he said so long as you make a note on the certificate that the customer is aware then its ok!!
whether he's full of poo poo i dont know i must admit i was suprised to hear it, he was talking new builds as well?!
Ive also heard this Sparkyork, in fact im doing rewires now for connect housing in leeds and we are putting everything back to the same heights as before as this is what the customer wants.
If you look in the osg it says that a way of satisfying building regs is to mount sockets etc at the heights they show. Your installations cert is done against wiring regs not building regs so noting the customer requirement on the cert covers you for wiring regs but I think the building inspector might pull it on building regs requirements in a new build. Another classic example of the right hand not knowing where the left hand is, let alone what it's doing!!!!
yeah it didnt really wash with me either but he did seem quite certain that if the customer wants to not comply with building regs on socket heights then it ok (but not really!)
Another bit of useless information which shows how things are written without proper thought being given to them.
When the building regs were first written about switching heights they included the mounting of cu and stated that the cu would require to be fitted with a suitable lock to prevent unauthorised access (children primarily). It was then pointed out that this could create problems in the case of lighting circuits tripping at night and so the lock requirement was not included leaving another total "cock up" for us to cope with.
Reply to CU Max Height According to Building Regs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
  • Locked
5K
All - Would appreciate some advise or professional help as I'm facing a £4.5K bill following an EICR which seems to highlight issues that passed...
4K
Hi all. I am not an electrician but greatly really appreciate some advice if possible. I am in the process of getting a full house rewire and the...
13K
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
I’ve mounted a Cu at eye level in tall cupboard unit, easy to see and reset if necessary.cruella da ville( customer ) now wants it moving 500mm up...
