Greetings,
I have finally been asked to do some work for a builder who I've been chasing for some time. However, he has asked me to install 20 sockets, 22 data points, spurs for blinds, a switcher and move the intercom. This is all taking place in an unfurnished office with existing dado trunking. The sockets and spurs are not a problem, its the data points, switcher and intercom that I'm worried about as I've never installed them before. I know I need to use cat 5e and RJ 45's but can anybody offer me any advice on the installation, connections and what tools I would need? I need to do this job, I can't pass on the opportunity.
Many Thanks
you need a switch panel at the server to feed to the data sockets. these a re connected using a 110 punch down tool similar the the telecom one. google data wiring and you'll find some info.
And a few sockets next to the switch panel!
Greetings,
Many Thanks
To add a bit more to the replies so far, You need a 24 way connection panel and a switch which will be connected to the internet, this could be housed in a glass data cabinet, run the 22 data cables to the RJ45s from the cabinet and remember to leave slack both ends, you will need a tester to confirm correct connection and ensure the cores are not broken or damaged.
Remember, all data points need to come back to a central point, ie a server room. By the shortest route possible.....each line can not exceed 100m
100miles? that's some length/
To be honest it will be a lot easier to buy he cables pre-made up rather than making them.
your right its better for cable inside the panel
really depends on the size, there not too bad to make.
it depends on the run, when we do a network for our panels it can be anything from 5m-50m+
have a short lead so that you can test points without disconnecting them
If the sockets are for computers then you may not want them all on a single circuit.
Make them high integrity socket circuit`s
I got one of them RJ45 crimp tools on Saturday to make a long ethernet cable that i needed and it worked a treat. I found a diagram through a google search on how to terminate.
London
Data points for an office
Computer and Networking Forum
Thread Tags
Prime Design,
diditrain,
