Discuss DC Volt stick in the UK Electrical Forum area at ElectriciansForums.net
You could try wading through Google
Click on the Google link.
12 – 24V Des.
I’m sure I’ve come across non contact DC detectors before, but where? I’ve a feeling they only detected a loaded cable. Pass it’s a long time ago.
The normal Volt stick is triggered by the alternating voltage field so only works on AC. On DC the voltage field is static and so you MIGHT get an indication when moving the probe through the field. You can detect a loaded DC cable using a magnotometer but these are very expensive.
In theory that should work quite easily (!)
Old Tony is probably referring to the 'Stick your finger on it and see if you get a belt' technique.
Old Tony, Thank you Archie! (Miserable old git)!
Up to 100V DC, OK I couldn’t feel it.
But the 120KV electrostatic systems made me cringe to switch them.
Reply to DC Volt stick in the UK Electrical Forum area at ElectriciansForums.net
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
Hello People Our Enphase solar system needs to have the AC supply shut down via the fire alarm contactors local input output unit that has NO &...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
