Discuss Dewalt multitool keeps cutting out, anyone else had this? in the Electrical Tools and Products area at ElectriciansForums.net
My 1 year old DeWalt multitool DCD355 now only works when I start it slowly and gradually increase speed, then if I touch a surface with it it will cut out.
Has anyone else had problems with these?
The light works fine, batteries too, it's as if the auto cutoff if the blade gets jammed happens nearing full speed or on contact with anything. I should have done the 3 year warranty online.
mught even be the battery. works on a light load but can't cope with the heavier load on cutting.
I did the 3 year warranty on mine.
Unfortunately, on day 1 of year 4, the multitool conked out. The terminal blade that connects the battery sheared off completely.
I tried a solder repair but it quickly broke due to the vibrating action.
Time for a new one.
Time for a new one.
You can buy new batteyr terminals or buy a broken tool off ebay, the battery connection bit made of black plastic is common across all 18v dewlat tools. I have repaired a sds drill for less than £20 buying parts vs nearly £200 for a new one.
also check if the brushes are sticking.
Reply to Dewalt multitool keeps cutting out, anyone else had this? in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
