When you compare the LAP and Robus, the light quality is vastly different. Not sure if everyone notices it but I certainly do. Do a bit of research, you can find the Robus ones for around £8 if you shop around (energy bulbs)...
that will be the colour of the light.
for example the ones im using in my bedroom are 2700k
Normally fit aurora 7 watt with aurora dimmer switches and they work fine. Fitted 4 in a bathroom a few weeks ago. Christ knows why they wanted to dimm bathroom lights????
Possibly to create an atmosphere when having a relaxing bubble bath, or so they don't get blinded when they get up in the night for a slash.
Nope, both are 2700k. The 3000k Robus are much cooler white than the 2700k. But the quality of the light, or the clarity of the Robus lamps is much better, whereas the LAP is bright but not that clear.
I prefer the single chip ie cob with a lens over the smd lamps. Bit dearer mind you.
If you compare the LAP fittings to other manufacturers, the housing is just plastic as opposed to an aluminium heat sink; possibly making them cheaper.
