ok let me batter your heads lol
added 4 new dimmable downlights to a room disconnected the ceiling rose and used that as my first downlight then i added to that and so on
question is when i turn off my lights the light still have a small glow.
my light switch has 1 x black in com
1 x black in l1
and the red wire has not been cut and is one complete cable
any ideas
Is it a compatible dimmer (LED), wattage, leading/lagging etc with the lamps/drivers you've got. Are the lamps dimmable?
Are the lights connected properly , polarity, (Including the cpc [earth wire])?
If all ok possibly faulty dimmer module.
its not a dimmable switch but the led's are dimmable its a simple on and off switch tried a few switches all the same all i have done is wire what was in the rose to the l e n onthe downlight and the other len is a cable to the next downlight. i thought maybe the black wire that comes from l1 was in the wrong l e n so i switched the l n but the outcome was still the same
If it's an old house the lighting circuit can pick up unwanted "capacitance" if the light circuit cables run near to other power cables. Watch the first 5 minutes of David Slavery's video on nuisance glowing LEDs
thanks watched it so i turned all sockets off was still the same think i understood that correctly lol
I fitted 4 of these in the bathroom on existing wiring and they do exactly that.
Fitted 14 in the kitchen, new wiring, no problem.
Havent got round to trying a snubber yet, or replacing the wiring.
Yea my
My knowledge on wiring is pritty basic I have an electrician due at mine soon think il.just ask him to have a look I will keep.you posted on what he recommends
1 x black in l1
This suggests that the supply cable comes via the switch and that switch is in the neutral. Apart from safety implications, switching the neutral could give the effect described due to stray capacitance. How many cables were at the original rose?
wales
dimmable lights wont turn off fully
Lighting Forum
geralltedwards,
geralltedwards,
