Discuss dimmable lights wont turn off fully in the Lighting Forum area at ElectriciansForums.net
ok let me batter your heads lol
added 4 new dimmable downlights to a room disconnected the ceiling rose and used that as my first downlight then i added to that and so on
question is when i turn off my lights the light still have a small glow.
my light switch has 1 x black in com
1 x black in l1
and the red wire has not been cut and is one complete cable
any ideas
Is it a compatible dimmer (LED), wattage, leading/lagging etc with the lamps/drivers you've got. Are the lamps dimmable?
Are the lights connected properly , polarity, (Including the cpc [earth wire])?
If all ok possibly faulty dimmer module.
its not a dimmable switch but the led's are dimmable its a simple on and off switch tried a few switches all the same all i have done is wire what was in the rose to the l e n onthe downlight and the other len is a cable to the next downlight. i thought maybe the black wire that comes from l1 was in the wrong l e n so i switched the l n but the outcome was still the same
Doubt the problem is with the switch then. Are they 230v units (ie integral driver)? Are they all terminated correctly?
If it's an old house the lighting circuit can pick up unwanted "capacitance" if the light circuit cables run near to other power cables. Watch the first 5 minutes of David Slavery's video on nuisance glowing LEDs
I fitted 4 of these in the bathroom on existing wiring and they do exactly that.
Fitted 14 in the kitchen, new wiring, no problem.
Havent got round to trying a snubber yet, or replacing the wiring.
Yea my
My knowledge on wiring is pritty basic I have an electrician due at mine soon think il.just ask him to have a look I will keep.you posted on what he recommends
1 x black in l1
This suggests that the supply cable comes via the switch and that switch is in the neutral. Apart from safety implications, switching the neutral could give the effect described due to stray capacitance. How many cables were at the original rose?
Reply to dimmable lights wont turn off fully in the Lighting Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi, The wiring for my lights have multiple COM wires in most rooms, which are a pain to screw into the COM part of the switch. The switches that...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
