L
liamruairi
Any advice is much appreciated. I have a new light fitted, 10 x E27 40watt filament bulbs. Its this one: 10 Lights - Edison Chandelier Pendant Lamp Ceiling Light Bulbs Remote Control | eBay
I have now fitted 5 dimmer switches and not found one that works. Leading edge dimmers buzz really loud and trailing edge ones keep blowing. I bought a 400w varilight remote dimmer which worked lovely, then i turned it on once (full brighness) and it blew. I thought i needed an over-capacity dimmer so bought the same but 600w version (max light fixture watt is 400 - 10x 40w bulbs) and same thing happpened. Worked dimmed for few hours, turned off, then on again at full brightness and it blew. What am i doing wrong? Do i need an even bigger capacity like a 1000w dimmer?
thanks for advice!
liam
1. Try a 1Kw dimmer a 400w is not big enough
2. How deep is the back box - if its 16mm or 25mm trying adding a "forward" spacer.
3. Fit an on/off switch
or
4. Change the light fitting
I had similar problems on a chandelier once , in the end I used a 1000W in line dimmer above the ceiling that had plenty of ventilation and replaced the switch with retractive one , never had a problem after that ..
the cold resistance of the lamps is a lot lower than when hot. use a rotary dimmer (as opposed to push) so that it's not possible to turn on full whack. lamps will last a lot longer as well. should manage with a 600w or 700w then.
Reactions: 1 person
Great advice thanks. Ill try a 1000w rotary simmer. Wher s a good supplier of a trailing edge ? Im in sheffield if anyone knows anywher thats not online?
many thanks
most electrical wholesalers will stock them, how about screwfux?
Reactions: 1 person
I'm from Sheffield where abouts are you op and I will try and tell you the closest one.
Thanks, im in nether edge. Screwfix dont seem to stock them in their catalogue but the nearest one to me is queens road opposite b&q (who dont have 1000w either)
cheers
cheers
yes you're quite far out at nether edge, the closest Yess electrical is penistone road hillsborough, edmundson electrical at catley road attercliffe or electric center near Sheffield arena, but I would say out of the 3 yess electrical have a better range of decorative switches and lights on display in store.
Unit 4
Hillsborough Trade Point
Rawson Spring Road
Sheffield
South Yorkshire
S6 1PD 3.4 Miles from nether edge
T. 0844 324 8025
F. 0844 324 8026
E. [email protected]
Mon - Fri 7.00am - 17.30pm
Saturday 8.00am - 12.00pm
Hang on a minute. The fitting the OP linked to says it includes a remote control, i.e. there is a receiver / control unit in the fitting that probably isn't designed to operate on a dimmer, unless the instructions say otherwise. I bet it contains a capacitive dropper to power its own electronics and that is what is causing the dimmers to buzz / fail rather than the lamps themselves. A larger dimmer might survive, but the control unit in the fitting might fail too.
E2A: if that is the problem, it could be bypassed, at the cost of invalidating the fitting's safety approval and warranty.
Reactions: 1 person
Yes it does have a remote control but it just turns all lights on or off, or 5 of the lights on or off at a time. There isnt a dimmer button on the control. With all the dimmers ive tried except from the varilight the fitting (im guessing the reciever in the rose) buzzed so loudly. Any work around?
Sounds like it is not designed to be used on a dimmer switch as it needs a permanent live so you can use the remote control.
Can i remove the remote transmitter / receiver and just wire dirt to the transformer? I dont need the remote justw want it to dim!
Dimmer keeps blowing
liamruairi,
liamruairi,
