Discuss Dimming LED's in the UK Electrical Forum area at ElectriciansForums.net
H
Hawk
I used the dimmable electronic transformer 35-105W (see picture) with a 12W dimmable ar111 LED and it dims ok. I thought that the minimum load had to be 35W?
@hawk, It is not necessary that the minimum load should be 35W as minimum load is not an issue but the maximum load should not exceed the 105W otherwise it will draw more current and it will damage the transformer. For 12W it is perfectly safe as it will draw less current and no harm from less current.
Have been recently speaking to osram and other manufacturers of LED product and on some of the products there is a minimum load requirement.
Minimum current requirement is there for some conditions. For a basic voltage step-up or step-down transformer, there is no such requirement but this requirement is placed for advanced power supply circuits where load maintenance is a critical parameter. It won’t go haywire but the circuit might not be able to regulate properly and there might be some noise if you don’t meet the minimum load requirements.
Reply to Dimming LED's in the UK Electrical Forum area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hi all, No electronic knowledge here. The plug/transformer of a led lightstring is fried. Now I am trying to find a replacement on Aliexpress...
