Can anyone help?
A customer has a light fitting in a bedroom (5 bulbs) which is switched two ways with a dimmer switch by the door and a switch by the bed.
He states that at some point he switched it on and nothing happened. He assures me they were working at some point before!!!!! He replaced all the bulbs to no avail, hence calling me in. It did seem strange that all the bulbs went in one go.
i opened up the ceiling rose and all wiring seemed sound. I did a voltage test to try and determine when the dimmer switch was closed. I couldn't get any readings at the switching wire at all. There was 240volts at the live loop, which was reassuring.
I disconnected the live to the light and did the test again. This time I got 240volts when the switch was closed and nothing when open ( I assume from that the switching is working properly). It must be the light fitting then. I replaced it with a pendant. Job done I thought. Switched it on and again nothing. On testing again I had the same result as before. The switching wire was dead whether the switch was on or off.
I then removed the bulb. Normal readings resumed - 240volts at switching wire when closed and nothing when open.
i asked the customer if anyone had interfered with the switch wiring or anything else before the light failed. He assures me they were working and then stopped working. It was a while ago though.
Has anyone come across this before or explain what is happening. Is is a neutral issue?
Any help would be very much appreciated.
Ian
