Discuss dist board change in the Industrial Electricians' Talk area at ElectriciansForums.net
H
heathelect
Got to change a 3 phase, 24 way dist board that feeds a few small offices and a small distribution area, the existing old board (dorman smith) has no rcbos fitted to socket circuits just old type mcbs. Question is under the 17th do in need to fit rcbos to rings feeding office sockets (computers plugged in) + other small office equipment ? or can it be classed as a dedicated circuit used by "competent persons" and therefore be protected by an mcb ? wiring to these rings is in ceiling voids and 100mm studding, nothing buried in plaster or less than 50mm from the surface. your thoughts would be appreciated, thanks dave.
Bit of a can of worms here but I would say that you could wire with MCB's with no rcd prot due to it being commercial and supervised by competent persons etc
defo rcbo mate, you cant call office staff competent people, the risk is still there.
Will be an expensive job.
i think youre right just wanted to reduce cost by fitting mcbs instead of rcbos.
By the way theyve been quoted 2K + vat to replace board by the company who did a periodic, do you think if i charge 1.8k it would be too cheap ?
Just done one the same (almost).
Pulled out old 36 way BILL deathtrap and fitted new PROTEUS board.
Now, I dont like proteus as a rule, but it was the cheapest way I could do it. Stuff like MERLIN GERIN was just too expensive.
None of the circuits were marked up, so put everything that was a ring or radial on RCBO's just in case. (apart from lights)
I quoted £1200.00+ VAT
Some may say its too cheap, but I have got the remedial works and testing to do so all in all I thought it was ok.
Reply to dist board change in the Industrial Electricians' Talk area at ElectriciansForums.net
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
