Discuss DIY Electrical: Help identify ground & neutral in the DIY Electrical Advice area at ElectriciansForums.net
sk_nj_diy
Hello experts,
DIY enthusiast trying to replace a conventional light switch with a smart switch.
Setup: The box has single light switch but 6 wires.
2 black: live & load
2 white: I assume are neutral
2 copper: I assume ground
Problem: The smart switch needs a neutral & ground. I am not sure which ones to use.
Here are the voltage differences.
Please help me identify the neutral & ground.
Hello experts,
My friend the white # 1 and white # 2 are your neutrals. Always the white wire is your neutral or natural gray, Black, red, purple, are live
[automerge]1593215935[/automerge]
Hello experts,
The ground is bare a lots of times but wire with insulation green is always your ground wire.
Thank you. Appreciate the help.
I will use both the white wires for neutral input & both the copper wires for ground.
I'm just a DIY'er, I'm not a professional - but I have to comment on this post - I'm always a bit uncomfortable with people saying "always the [colour] is your neutral/live" etc.
In my (very) short time wiring, I've noticed some misuse of colours/cores and you cannot bank on the sleeving to determine what you're dealing with, that's too much reliance on people's competence who have been there before you.
Reply to DIY Electrical: Help identify ground & neutral in the DIY Electrical Advice area at ElectriciansForums.net
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
