M
mort2376
So found a mains cut out in a very bad way. Top of the fuse cover had snapped off and the fuse was not pushed in fully.
Rang the DNO as was changing the consumer unit and explained the situation that it was dangerous as the fuse was exposed and you could put your fingers directly on the live parts.
24 hours later they turn up and change the cut out. All well and good, but I thought that they would seal the cut out to prevent further tampering and maybe upgrade the 6mm providing the pme connection as well ? But no. Arrived 9:30am cut out changed by 10am sat in the vans ( 3 people 2 vans to change a cut out ! ) till 11:00am then left.
Thoughts anyone ????
Pics are below.
Pics are below.
