Read the ' garage earth ' thread, that's still ongoing kind of !
If you spoke to 50 sparks, 25 will tell you one thing and the other 25 will tell you the another.
Then they'll argue amongst themselves a while whilst you have a brew.
seems like a bit of a grey area.
So there's a a 13A FCU from the ring final that the SWA connects to?Fed from a spur on an existing ring inside the house
So much more info required josh!
And maybe 5 would understand why their doing it which way!
10A on skts as the FCU will have max 13A fuse.Ok, I would put garage RCD protected CU in shed. 16A radial for sockets. 6A for lights.
Export earth from house.
Its not rcd protected in the house thats the reason for the cu in the shed.
No extraneous conductive parts & the shed is made of wood.
I'm not sure .I've always put Rod in but saw an article and it said it could create problems
