Am I the only person who doesn’t ferrule flex...??
the only time I ferrule is if I shorten an Rcbo N fly lead , that’s about it for me
as for ferrul ing plug tops , are we having a laugh
Depends. Control panels, always....lamp holders and plugs, never. But if you notice, for applications, all small flexes come with some sort of hardened crimp or ferrule.....even 13amp plugs and flexes on ceiling roses....like those fly leads you mention.;)
It is definitely good practice to ferrule fine stranded wire, even with clamp-style terminals, as it also serves to reduce the risk of the stands going astray. Often pre-assembled fine wire things like pendant lamps, extension leads, etc, are ferruled.
But for many cases when you don't the ferrules & crimp tool to hand, such as fixing a 13A plug at a friends, then I double (or sometime triple) up the wire so the clamp screw has a decent volume of copper to grip.
The issue of plug tops is the fine balance of getting a tight termination and the grubscrews actually damaging or thread riding the fine strands, of course this doesn't really have a large impact of very low loads as the cable CSA is normally oversized by several orders thus room for such issues but heavier loads are very prone to having issues caused with not using the appropriate ferrule on the termination.
The regulation are clear that you should use them even on plugs hence all manufactured pre plugged item if not moulded are ferruled as are other flexed items like drops.
Is it overkill, sometime yes but other times definitely not, the variety of plugs out there and there design of termination hole and grub shape makes it hard to argue that ferrules are not needed, many grub screws are actually finished with a pointed end which promotes fine wire damage and actually pushes fines wires up the threads.
For me it comes down to been aware of the problems to whether you do ferrule a plug but if we are to adhere to the regs then yes it is required.
I basically only ever use flex (as we build trailers), so use a lot of ferrules.
Don't really see why you wouldn't? it only takes seconds and usually fits into the terminal easier, and a much more solid connection.
For sockets, or anywhere where you need to get 2 wires into the same terminal, i just pull the bootlace off - so they are just uninsulated ferrules, as the boots get in the way.
Or you can get double ferrules.
For ELV stuff, i usually just tin the end with solder.
Liverpool
United Kingdom
Business Name
Banksy electrical
Does flex cable need to have boot lace connections
BanksyElectric,
Timbo,
