Discuss domestic rhi forms pros and cons in the UK Electrical Forum area at ElectriciansForums.net
Hi doing barn conversion for parents. Fitted air source heat pump. Applied for rhi payment but bit stuck. Want to no if ocupied for 6 months or not. If not get a meter or more than no meter. Would i benifit from having a meter or not. Any ideas
You may like to rewrite your question, Simon, it's hard to decipher without punctuation marks
I cant work out your post properly but don't you have to be a MCS registered installer anyway so the customer (your parents) can claim the RHI.
Having a heat meter fitted does not give any benefit under the domestic RHI as annual payments are capped at the maximum EPC annual kWh value in any case, which is what you would get paid with no meter.
Just wait a while to submit the RHI application until the answer to the 6 months occupancy question is 'yes' although the tariff might drop by a fraction.
Reply to domestic rhi forms pros and cons in the UK Electrical Forum area at ElectriciansForums.net
The results of the consultation and resulting proposals have been published today and can be found here...
danesol
A
Renewable Heat Incentive to open for applications 25 November 2011 Press Ref: 11/101 Businesses and communities across Britain will from Monday...
P
Got a couple of Q's that any ideas on would be appreciated. Lady down road has 16th Ed CU fitted by her ex husband just before he left her. It's...
Poptasticdave
P
F
FIT payments - A cut too soon, a cut too Deep and consequences thereof: Why a cut to FIT tariffs is necessary: It is necessary because the FIT...
babba
B
