The cable doesn't look big enough to be three phase, could have originally supplied four single phase, or that's all they had on the van 50 odd years ago.
Upvote 0
It is a bit odd. I have a 3P supply into my place, cable looks identical to be honest. Would the DNO supply 4 SP supplies with the common neutral block? Dunno, I would give them a ring, they are really good round here (WPD), I have the local teams number and they are only too happy to come out and have a look. They might even make you a nice bacon butty in their custom built kitchen/van. They have a nasty habit of leaving seals lying about as well.....
Upvote 0
Quite common around here. loop feed 1 supply to 4 adjoining houses. our old house was a semi with the loop to next door on our service head.
Upvote 0
Cable could easily be 4c and yes looks like a relic of looped services. Probably too old to have been put in for electric wet CH, although if someone did request a TP+N supply for some reason (I've seen it in a house that was used for some kind of war work) the pup fuse might have been a looped service or to take the existing SP+N supply on a separate meter. Not ideal that the present supply is off the pup, IIRC UKPN limits them to 60A although that tends to assume there's also a service running on the parent. New S7 pups are limited to 30A max partnered with 60A.
Upvote 0
script>
Upvote 0
"Pup fuse" - can you explain L? Haven't heard the expression before. Cheers.
Yes I am a bit confused as well Lucian, how it it looped if the fuses are not terminated? Or are they just using the I/C side of them to daisy chain the next one?
Upvote 0
I assume the "pup" fuse is the left one as it seems to be an add on.
Upvote 0
