Discuss Domestic Supply ? in the UK Electrical Forum area at ElectriciansForums.net
The cable doesn't look big enough to be three phase, could have originally supplied four single phase, or that's all they had on the van 50 odd years ago.
It is a bit odd. I have a 3P supply into my place, cable looks identical to be honest. Would the DNO supply 4 SP supplies with the common neutral block? Dunno, I would give them a ring, they are really good round here (WPD), I have the local teams number and they are only too happy to come out and have a look. They might even make you a nice bacon butty in their custom built kitchen/van. They have a nasty habit of leaving seals lying about as well.....
Cable could easily be 4c and yes looks like a relic of looped services. Probably too old to have been put in for electric wet CH, although if someone did request a TP+N supply for some reason (I've seen it in a house that was used for some kind of war work) the pup fuse might have been a looped service or to take the existing SP+N supply on a separate meter. Not ideal that the present supply is off the pup, IIRC UKPN limits them to 60A although that tends to assume there's also a service running on the parent. New S7 pups are limited to 30A max partnered with 60A.
script>
I assume the "pup" fuse is the left one as it seems to be an add on.
A pup is an additional fuse mounted next to the main one, fed from the second terminal on the incoming side via a U-link. The service cable termination in the main fuse has to carry the current for both.
Thanks for that info Lucien.
Cheers for reply's. Yea its a strange set up and the house is a semi detached late 50's build. So gutterball you reckon its restricted to 60 amps? and what sort of work is involved to up the ampage? new head on supply or new cable from street :eek:£££
Thanks gutterball. I take it the other fuses then would have been for other properties and are not in use on the photo i have posted then? And is it a big job for the dno to upgrade the supply head for a larger fuse?
Reply to Domestic Supply ? in the UK Electrical Forum area at ElectriciansForums.net
I'd appreciate the wisdom of domestic sparks here... End terrace early 20thC house: Supply: I've not seen the likes of this before in a house...
Hi, I’m an industrial electrician, so when it comes to DB regs and such my experience on them is a little limited. I need 2 x 16A 3 phase supply...
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
