Discuss doorbell setups (wired) in the UK Electrical Forum area at ElectriciansForums.net
P
Phillcbr400
I know these are pretty straight forward but not having fitted one before I thought I would ask first.
Looking on TLC I think ill go for bandera door time and the TC TRV transformer. Transformer will be about 10mtrs from the chimer. And using alarm cable doubled up.
This chimer has a separate sound for the back door, I was thinking of using this with a simple magnetic door contact for an entry chime. Question is, would this work.
Just got too find a nice button now :)
If you have any preferences with using certain makes or models what are they? Only want a wired system.
Phill
Is there a magnetic contactor/ or other device I could use for this application? It's in a domestic property so needs to look discreet.
I've been having a look around the net and not seen much.
A low powered relay should be ok, if your any good at electronics can draw you a simple 2 transistor switch...?
Only done basic electronics if I'm honest so you might just lose me there tazz. Always willing to learn tho.
Thinking a relay and transformer in a nice enclosure next to the consumer unit might be a good option. I can run a switch on the back door aswell.
You're an absolute star for doing that tazz, appreciate it a lot. Very kind of you.
Lucky I can pick must of the gear up through work so shouldn't cost me much.
Say I was wanting too add another 2 door contacts onto this, how would I then go about doing this? As the only problem I can see with making up another switch or even running multiple contacts on this one, is if one contact is already open and there is already a supply to the chime/bell then another one wouldn't make a difference.
Because there is virtually not current at the contacts, you can run as many as you wish, just wire in series with existing
My fault, woops! Although in my defence the circuit symbol shown is a standard normally open switch. Daz
The only problem I can see with this setup and i am most probably wrong is will the chime keep belling out if the contact is left open, and if using multiple contacts in series, one won't activate if another contact is already open.
Have you considered getting a decent sized bit of paper and a pencil and drawing the circuit out?
THEN maybe you'll see how it all works - or not?
Reply to doorbell setups (wired) in the UK Electrical Forum area at ElectriciansForums.net
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
Hi, So I ended up with a Ring video wired doorbell instead of a Byron video wired doorbell as B&Q were out of stock (had ordered online) and they...
