Discuss Double dimmer switch - swapping round switches in the The Welcome Forum area at ElectriciansForums.net
Rory Edwards
Hi all,
I'm a bit of a novice when it comes to light switches but managed to wire a single normal switch a few years back so thought I'd be okay with tackling this job but in truth I can't work out where to start!
The issue is that in our living room we have a double dimmer switch but the switch on the left controls the light at the right of the room and vice-versa. I want to swap these around so that they both control the light that is on that side of the room but having looked at the wiring I can't work out how I'd do this.
Any advice would be much appreciated!
Thanks,
Rory
If the wires are long enough just fit it the other way around. Where does the blue wire connected to the terminal (earth) on the front plate go.
That's what I meant but I suspect the blue wire goes to the back box and it ain't long enough.
That's correct- unfortunately the blue wire isn't long enough to swap around ☹️
The blue wire should be marked g/y so I would replace it with a longer piece marked correctly and turn the dimmer round
If the wires are long enough just fit it the other way around. Where does the blue wire connected to the terminal (earth) on the front plate go.[/QUO
Just swapping the dimmer modules round may not work...they are asymetrical often which is why one is upside-down, so to speak...it all depends on the length of the wires feeding them
Reply to Double dimmer switch - swapping round switches in the The Welcome Forum area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
