Can these be drilled?
The diagonal beams going up to the roof that is?
Has it to be boarded?
Yes Needs to be boardedHas it to be boarded?
I thought but I'm not sure you could drill rafters though?Look like 4x2 (95mm x 45mm) rafters to me. Tile baton and roof tiles the other side I imagine.
20 mm max hole through the centers should be fine. Though if the roofer has used 3" nails to fix the tile baton you may come across them!
If the roof has been battened and tiled the id be tempted to drill high of center to avoid the boarders screwing in.Yes Needs to be boarded
Thats how i feel but is it allowedI personally don’t like drilling roof rafters
Due to de rating factors?Also... if there's board going on the top of those rafters... I'd imagine there's some insulation going in there too ? Celotex ? How's that going to work with your cables ?
