Discuss dual fuel central heating system in the Central Heating Systems area at ElectriciansForums.net
B
big willie
Can anybody tell me where I would find an electric diagramme for a duel fuel central heating and hot water system (oil boiler with solid fuel stove with back boiler) The system is fully pumped except for the hot water from the stove is gravity fed.
Thanks anybody
Reply to dual fuel central heating system in the Central Heating Systems area at ElectriciansForums.net
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Hi all, my condenser boiler central heating has started to do strange things so I set about trying to diagnose the problem. When I got to the...
4K
Hi everyone, my house has an air-to-heat system that generates hot water in a boiler. This boiler is then connected to the central heating...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
