T
The Ghost
£189.00 and well they did say that at the show though so wasn't a complete lie!
You would be surprised what happens when they know you are fully aware of your rights, a warranty is just a no hassle exchange of goods, when that runs out you need to present your case but less than £100 quid you have to question is your time and getting it independently checked cost effective (don't let them do the checking for you, they have an interest not to pay out).I think I'm toast with a product at under £100, 3 years old?
I think navigation and the menu system is a bit obscure but megger were really good on support for the product and phoned me personally when I raised a question. Because the clamp is shielded you can put it around the two incomer tails and it works out the difference between them and bases the difference on the earth leakage on the whole installation. Indispensible when the dread call comes "My RCD keeps tripping!"consider that megger
By what you describe I would replace the batteries and check for corrosion on the battery connection tabs ... the symptoms are similar to a voltage drop of the battery as it runs out, this can also be caused by corrosion if you had it on the shelf for a long time and the batteries have leaked and/or the points corroded.
Well yes, I was using them around the main earth or a funny trailing socket with the earth looped out of the flex to test on that earth. Call me stupid but...err hang on don't bother!I thought that's how those 'earth leakage clamps work
just wondering why anyone who is not into S&M would want their clamp metering (or is it meter clamping).
