Discuss Earth leakage clamp meter in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
Anyone got one they recommend.
Looking to spend upto £120.
Would like micro Amp resolution if possible single digit milli Amp a must.
Ta muchly.
Edit: only looking at testing appliances and 240V circuits.
(did a search but no conclusive answers found)
if you can find the 1961 episode of Blue Peter, they made one with a coat hanger hook, a magnet, and a toilet roll middle, coupled to a compass calibrated in mA.
Bloody Blue Peter.... I remember telling me mates dad (a very hard man:cool:) that i watched it,and they were burying a "time-capsule"....
"Oh,you like digging,do ya?..."he said...
The following Summer,at age 13,he had us digging in railway crossing timbers,as gate/fence posts....holes dug by hand,3 foot square and the depth of the shovel...sides shaved plumb and the bottom flat,level and clean. Posts punned in every 6",gate posts concreted in...
Yeah,thanks Mr.Noakes...:rolleyes:
Only problem with cheaper is that they probably wont be adjustable if it goes out of its factory calibration.
You are correct but I could confidence check it against a calibrated MFT when, say, doing an RCD ramp test.
In a way, within reason, the absolute measured value is not important so long as you know by how much it's out.
I'm looking for an indicative diagnostic tool not something to offer a certified figure.
As such paying upwards of £250 is going to offer me little other than probable longevity.
If the cheap and cheerful proves incredibly useful yet wanting then I will have the justification for spending more. If it spends more time on the van than in use, which I suspect, I've made the right choice.
I think you'll find the cheaper ones only test milliamps by clamping across both tails, whereas the megger (bucks) tester will also clamp a single conductor, useful for a test of leakage on an earth wire.
As an aside, I don't have one and fault find with just an IR tester, leakage clamps are by no means essential.
Any clamp tester will measure the current in a single conductor you clamp it round or the imbalance in current between any group of conductors you clmap it round.
There was an MTI brekkie morning at our CEF a while back and I looked at an ETHOS earth leakage clamp which was around a hundred quid. It would only measure leakage current by clamping both tails,(that was stated in the manual), the guy told me all the cheaper clamps work like that and will not read milliamps from a single conductor. If that is incorrect it was from the horses mouth so to speak.
That's two seperate things, the ability to measure milliamps and measuring leakage aren't the same thing.
The ability to measure milliamps simply means that the meter is capable of measuring small currents.
The only way I know of measuring leakage current is by clamping all live conductors of the circuit in question. Clamping the cpc won't tell you the leakage due to the parallel paths involved, plus the leakage may not be to the cpc of the circuit.
Reply to Earth leakage clamp meter in the UK Electrical Forum area at ElectriciansForums.net
I recently borrowed one of these to diagnose an earth leakage problem, and it was very useful: 560 60A Digital Earth Leakage Clamp Meter -...
4K
Hi everyone, Any suggestion for an Earth Leakage Clamp Meter within a reasonable price?
Hi all, looking for recommendations for an earth leakage test meter for RCD work that doesnt cost a fortune. Thanks in advance.
Hi It’s a bad setup but I went for a call out in the night in a residential unit. There’s a rcd in its own enclosure feeding a 14 way board that...
