Discuss EICR - 2 boards, 1 with an off peak split and one with regular supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi there, im looking some general advice related to this eicr.
im a bit lossed here, so would it be 2 eicr?
or do i just splice two sheets together with the relevant information?
on a seperate not i also noticed today when i had a wee look that his main water bond cannot be verified, is this a dealbreaker?
i mean i see a group of 6mm earths leaving the board(with no other purpose) but theres nothing at the stop cock.
It a block of flats (circa 1970)
Any advice would be greatly appreciated and also if anyone could recommend a specific course that teaches all the in/outs of eicr?
would it be 2391?
I mean your tradesman shows you testing and you get it at college and then you pass the test etc but no one really goes into detail and tells you how to deal with eicr(s) etc
haha, maybe so.
specifically im talking about the section of the eicr that asks for the details of the main switch (its before the circuit chart page and test results)
It asks for the main switch details.
So if you have two different boards with different main switches then my thinking is that both these details should be recorded.
Im not saying i know it all, and if i cant find an answer then i most likely just tell the guy that im not going to complete it.
I do try and do a good job for people.
Any advice on a course?
Don't worry Neon, you'll get some helpful answers soon. I think it's an ok question apart from the bit about the lack of Main bonding being a 'deal breaker', I'm not sure what that means.
If the incoming water supply is in metal and there is no main bonding visible (can you see all around it?) then I would code it C2. If I couldn't see all around it then I would code it FI.
I would also test it to see what resistance it has to the MET. I do get a little confused with the 0.05ohm figure, but if there is a 6mm leaving the CU and the stop cock tests <0.05 to earth then I think it highly likely it's got a Main bonding cable attached to it.... I wonder what replies I'll get to that! (Plus the 6mm would have to have been in place for a significant amount of time and show no signs of thermal damage if it was to be classed as ok as it should be 10mm)
thanks for your reply.
i just meant that it would be a fail without the verification?
I would note it as a c2.
it can be clearly seen where it enters and the bond is not there.
Maybe it attaches somewhere else in the house (after the "t", who knows)
I dont think i would mark it down as verified with just a test, id have to see it.
yeah i know it should be 10mm but these 6mm do look old, and i think they used to do it with that all the time.
thanks
haha, maybe so.
That is referring to the main switch of the whole installation, not the individual DB's. If there is no single point of isolation then N/A that section and note in the recommendations page.
No course can prepare you for EICRs ..... only years of hands on experience ..... and that needs to be across a variety of sites and installations
well thats what im trying to gather the now, but i think that if you dont ask questions then you will never learn anything.
Even if it might seem ridiculous to other people.
I think its worse to ignore your own ignorance?
ah right, so why does it ask about bs number and rcd ma rating?
ive never seen a main switch (ie the one directly after the meter) with an rcd on it?
I believe for someone to carry out EICRs they must have an expansive knowledge of electrical installation methods, past and present. A thorough understanding of current requirements and how these may or may not affect existing installations. The ability to produce a factual Report with concise grammar. Most of this cannot be achieved in a classroom.
Well, would that not mean that only electricians who lived through the 70s till present day could do an eicr?
I do understand broadly what you mean,and i agree that this qualities you mention would be very valuable, but it doesnt seem like a practical approach.
At the end of the day, people are required to have their properties tested etc so there has to be a mechanism for providing people the knowledge to have this done?
I partly agree with what you say, but you need a little knowledge.
And I truly mean no disrespect with this next bit.
I don't think you have that based on what your asking.
You have to start somewhere, I know. But for now get a bit of experience. Avoid EICR's and do them after that experience grows a bit and do the 2395 or what ever the equivalent is now.
I think Spin is saying that two CUs from one single supply is classed as two installations.
A great attempt at trolling but not good enough to catch me out.
You haven't been drinking enough tonight have you? Must try harder Essex!!!
3 Phase supply into the basement of a building.
Ground floor shop, first floor flat, second floor flat.
One supply, how many installations?
Oh yes, and of course there’s also the fact that a single installation can have more than one supply
In this scenario, 1 install, 1 certificate, 2 boards.
There are plenty of RCD mainswitches in Scotland, where an inline RCD has been fitted to the tails before the board as an easy way of complying with the regs back in the day (although less than ideal now).
Another example would be a TT installation with a time delay RCD upfront.
Oh dear, what a string of posts. OP, ideally you need to get experience working alongside some other electricians experienced in carrying out EICRs. C&G 2391 is the current qualification in inspection & testing covering both new installation and EICRs. Guidance Note 3 is an excellent purchase to help improve your understanding.
I understand why some get hot under the collar when electricians with limited experience in I& T jump in without sufficient support, given that you are certifying/reporting on an installations suitability to be energised/suitable & safe for continued use.
The best advice I can give someone involved in I&T is to read, understand and apply the standards/guidance available, understand what you are testing for and why, know, understand and be able to interpret the results you obtain, and never forget that a poorly designed, installed or maintained installation can lead to serious damage and/or loss of life. It’s not to be taken lightly!
Here endeth my sermon
We do a lot of EICR's and I see some by local registered contractors that say things like 'no power - cannot test' (apparently they have not heard of dead tests) and 'needs a rewire'- which may even be true but is not a defect on BS7671
You are not doing EICR's for landlords are you?
Reply to EICR - 2 boards, 1 with an off peak split and one with regular supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
HI , potential 2 bed 1970’s bungalow buyer here…. Our surveyor (RICS) has pointed out there is no circuit breaker to the electrics (fuse board...
Hey guys, Im starting to put my company out there more. And this is all a new journey for me being an apprentice and now being qualified/2391-52...
Hi All, I am looking for some expert advice on EICR sets etc. I live in a rented house which has a private water supply, meaning we have to change...
