Discuss EICR and RCD's. Is it a C2 or C3? in the UK Electrical Forum area at ElectriciansForums.net
Thank you all and everyone for their comments.
I won't comment whether I am a 'greedy landlord', I certainly
don't wish to be taken advantage off. Equally I don't think I take advantage of others.
Re-capping:-
1) 2nd Floor flat in a block built NEW in 1997.
2) Five years ago I have a satisfactory EICR.
3) Now I have a C2 (Potentially Dangerous). This rating can be changed as I have a quotation to "fit a new fuseboard to meet current regulation" - as written by the electrician. A new fuseboard solves my problem?
Logic question - Why is it a C2 if RCD's are NOT mandatory given it was satisfactory five years ago? Why wasn't it a C2 five years ago?
Thanks everyone again.
Please read my last post send that report to Napit and ask for their opinion,, if u can post response on here thanks
How much do u get charged in LONDON THESE DAYS FOR A EICR
There a pic of the Napit code book for the OP
Hi
I've invested on a EICR Codebreaker Via Napit earlier this year and had the previous version for 17th Edition which is a Good bit of Kit to add to your tool bag, I'm sure NICEIC & other Bodies have their own versions for members or non members
So regarding C2 or C3, 2nd floor flat you probably wont dangling a extension lead out your window to clean your car, but ground floor & 1st floor its likely as i've seen it so many times, so on 1st Floor & ground Floor, I Code C2, BS 7671 522.6.202, sockets which can be used outdoors
Also no cables with no mechanical protection ie. not in steel conduit ot the likes of, in stud walls or cables buried in walls less than 50mm as most solid walls are 100mm so either side will be still venerable for a cable to be penetrated by a nail or rouge Screw by others C2, BS 7671 411.3.3
I don't look for making extra work for a EICR's or extra money for the sake of it etc, but safety of the Property and Safety Life, as you can not put a cost to someone life, so to clients to spend a few hundreds to get up to date as RCD's are life savers regarding age of installation, I always recommend on a inspection to upgrade any issues to bring installation to a good standard RCD's or RCBO's to future proof for now and btw this is just my opinion & 90% of my clients & Landlords & Landladies will also agree.
As I also do work for Local Governments & Authorities they now have started to replace D.B.'s when tenants leave their properties if any additional circuits needed all D.B. to have RCBO's and S.P. as standards to meet 18th Edition
Kind Regards
Tony Jelade Electrical Services
It's not compliant with section 314. That's not up for debate at all.
Lighting circuits can have RCD protection added at any point on them to facilitate alterations.
How funny I've just been having this discussion with my knowledgeable supplier as I have to do and EICR on a 7 way wylex board with no RCD and he said as I can't prove that the cables are deeper than 50mm and the customer does not want to a new board then he suggested an up front RCD.
I've just read section 314 and I interpreted it to mean every circuit must be RCd protected not a batch of circuits I.E like the 5 and 5 way boards.
can you point out please how I'm reading it wrong
Surely if its an EICR you don't need to provide an rcd unless the client has asked??
314.2 the failure of one circuit shall not affect others.
See the reg for the exact wording.
Selectivity.
upfront rcd trips, everything goes off.
your knowledgable supplier is well out of date.
As is this thread.
Thanks for you reply but can you answer my other question which was if the RCD should not trip other circuits then how come we fit split load boards?
confussed
[automerge]1593442977[/automerge]
Very true but we are often accused of stitching the customer up so knowing its an old board with no RCD fitted and if we are saying that its a fail with no RCD, then I'm trying to give him options other than a new board if that's possible.
confussed
Mark it unsatisfactory. Then personally I would say a new board would be the best course of action if he declines at least you've done what you were paid to do and no one can argue with you on that
I think the problem is that there is mention in the NAPIT Codebreakers that gives it a C2. It also mentions that previous editions of BS7671 don’t necessarily warrant a c2. (Open to interpretation).
i personally think that if there is clear evidence of additional sockets/ switches being installed at a time when RCD protection was required then it warrants a c2 and that "new" fitting would indeed require RCD protection. However, if it is clear old existing circuitry and accessories that complied with an earlier edition of bs7671, then at most, a c3 with a strong recommendation of upgrading to RCD protection which the client can choose to do or not.
The important thing with this is that the installation is safe in terms of no degradation, overheating signs, correct earthing and bonding, high insulation resistance, low zs etc.
As DSES has already said, you dont take one look at old colours and make it unsatisfactory, recommending a rewire because 18th edition says we use new colours!!
If there was no supplementary bonding in the bathroom or RCD protection to the circuits that warrants a C2
Exactly what i was thinking!
[automerge]1593541730[/automerge]
Some of our tenants have the mem boards fitted in 2005 or before . Ones where some is rcd protected other half isnt. When doing eicrs its a c3 that cables less than 50mm are not rcd protected and also c3 that lights arent rcd protected.
If however we want to do work on these circuits we either swap the mcb for an rcbo or move the mcb over to the rcd side.
As for an upfront rcd not being compliant...so you have a client with an old cartridge fuse board asking you to put an extra light on the circuit...not that big a job...you're going to honestly turn to them and say
Yeh well first im going to have to test the whole install as i have to change the whole board.
As i suspect dave from the pub would soon happily be used instead
[/QUOTE
I use an rcd fcu
Reply to EICR and RCD's. Is it a C2 or C3? in the UK Electrical Forum area at ElectriciansForums.net
Hello. Non-electrician here. Failed an EICR yesterday as the electrician graded my consumer unit C2. Why C2 and not C3? He didn't say (and still...
Hi guys, need a bit of advice, EICR was completed on the property which needed a new consumer unit and a few other bits like broken sockets and...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
I would greatly appreciate if someone could help me understand the following outcomes on an EICR. I am being advised it needs a total rewire but I...
4K
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
