• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss EICR in Huddersfield - but first do I fix this possible danger? in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Hi all
I have an investment property (1 bed, Milnsbridge, Huddersfield) which I need an EICR for.
But there is a very corroded looking section. Forgive my naivety, but I'm assuming this is connected the electrical board. Is that the case (see pic)? The board is in the kitchen which is a cellar kitchen.
I'm guessing I should get this fixed before booking the EICR (please feel free to quote if available!) Is this relating to the supply cable? If so, do I ring 105 as I'm also concerned about any possible danger. God knows how I didn't notice this before buying the property!
Thank you
Looks like your main supply prior to the suppliers cut out and therefore their responsibility. If you have concerns contact your network operator and ask them to check it out.
Or to help with a better photo!
In the meanwhile you could always remove those combustible materials prior to a visit from the DNO?
Taking that it looks like it has a bs951 bonding strap on it - it looks to be a metal conduit leading to the cutout.
Question to the forum massive - Is that one of the shared feeds to the cutout and then going to another property? Haven’t seen one before but know they exist.
Thanks everyone, some great (and friendly) info on here. I'll call DNO first (hopefully for some peace of mind) then book the EICR. Do any of you have a recommendations that cover the Huddersfield area?
Thanks again!
Reply to EICR in Huddersfield - but first do I fix this possible danger? in the Electricians Jobs area at ElectriciansForums.net
Hi, First time buyer here who is purchasing a 1970s 3 bed semi detached. No idea about anything electrical but the vendor said the electrics are...
4K
All - Would appreciate some advise or professional help as I'm facing a £4.5K bill following an EICR which seems to highlight issues that passed...
4K
I had the first EICR done on my flat last week, which failed with some C2s for having an older (2001) plastic consumer unit with no RCDs, but...
Hi, hopefully, you can help me by giving some guidance over the EICR which has failed for my rented property. It was carried out by an electrician...
4K
