Discuss Electric shower fitted on the wrong end of bath. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all,
Recently did an Eicr. I failed it due to shower being fitted on the opp side to the taps. I was lead to belive it was a C2 fault. Unable to find anything in the regs. Building or 18th. Its a rented property with a tight arse landlord who's asked his mates and come to the conclusion that he doesn't have to move it. Any feed back with relevant regs would be helpful. Cheers Kellogs
Surely a wind up. Hope it’s not serious, there is a real business of that name in … let’s not be specific …but I’ll call it Essex.
Could the taps not be moved to the shower head
I would put c1 for the hole to be in the correct position.
I am afraid your lack of knowledge of plumbing regulations is showing. The real problem is the bath has been plumbed in the wrong way around. So it really does not come within BS7671 etc. So no code.
This can't be real, there is looking for problems and the there is..... this when the only problem appears to be the guy producing the EICR
I find it rather worrying that with all the talk of what is deemed competent to carry out EICR's somebody would post this question
Not really a good advert for the OP especially with their business name in their profile
It’s C1, C2, C3 for things actually checked and be coded.
FI for Further Investigation
NV for not verified. Means it’s there, but I couldn’t physically test it / couldn’t be bothered.
NA no applicable. It’s not there to be tested.
Reply to Electric shower fitted on the wrong end of bath. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
A relative recently had an electrical certification done on a rented property. The property was build in 2005 and had previously passed 3...
Hi. I'm being tasked with installing an electric shower into a property that was built back in the 1980's. The main consumer unit has only 4 ways...
Evening all. Doing a EICR in a rental today and presented with this. installation date is 1992 and there seems to be no records since. At some...
11K
