Discuss Electrical certification for house? in the UK Electrical Forum area at ElectriciansForums.net
Hi Pete. Yes possibly as it has a fairly new(ish) bathroom.
I've just remembered also it used to be a separate bathroom and toilet.
I'm wondering if that means the other cable is the other switch wire which has most likely been buried and left connected to the live part of the loop!
Just a thought but I had my bathroom done a few months ago and the" Electrician" was the same bloke that did the plumbing, needless to say I did the Electrics, it could be you have had Bill the bathroom fitter do the electrics in your house, if you can find out who did the bathroom you could confront them, a long shot I know.
It just makes me wonder what is the point in electricians having qualifications when some cowboy can just make a pigs ear of my wiring and ride off into the sunset. Does that mean that there is no real sure way of checking these things?
I mean, when I bought the house, there was no mention of certificates etc. I remember the vendor mentioning the new consumer unit and the additional sockets in the bedroom were "recent".
This is something your solicitor should of insisted on if it was evident from the survey the consumer unit etc had been replaced.
Yes IIRC it was mentioned on the survey that it was "part rewired" but I don't recall the solicitor bringing up as an issue.
If he done his job properly then he should of asked for them and if they wasn't forthcoming then an EICR could of been conducted which would of probably highlighted the defects which in turn you could of used as ammo to reduce the cost. Maybe take it up with the solicitor as there will be a paper trail?
You don't need a certificate to sell your house. If you're unhappy about the wiring it may be wise to get it checked for your own safety if you have concerns. A buyer may want to get it checked prior to purchase, then any issues uncovered will be a negotiating point between you and them.
Thanks Lee. To be fair I got a fairly hefty discount off the asking price when I bought the house I doubt I would have pushed them down further.
I've got a decent bit of equity in it already.
It's my own fault really for being a bit green...first house purchase so didn't know the ropes.
I will definately need the meter and dist board moving when I do the extension and I want the ugly surface mounted cables shifting too so will be a good opportunity to have it all checked out and brought up to standard.
Thanks Alan. Does that mean Joe Bloggs could do his own DIY rewire and as long as some numpty like me buys his house he can get away with it?
Erm I guess I am the proof of the pudding lol
There are clear regulations about what you can and can't do electrically and who is competent to do so. However, as far as I'm aware it's still very much buyer beware re wiring much like the depth of the structural survey that will be done as a requirement for the lender. Very few houses will meet current regulations as the regs are updated all the time and are not retrospective and it doesn't necessarily mean they are dangerous. So in answer to your question, yes, if you don't get the wiring checked before purchase it's very easy to buy a lash up. If you did identify work that needed doing you may want to factor that into the purchase negotiations. If you are selling and you have concerns, at least for your own safety get it checked to ensure there is nothing dangerous.
Thanks Alan.
From your 1st post apart from the cables in connection block you are asking how things have been wired,just because something looks messy does not make it unsafe saying that I think you need a good electrical installation condition report and I'm sure that they can advise what needs to be done (you need to let them know also you need to know the outcome noted in your post.
Part P came into force Jan 2005 so any work under the part P at the time should have been notified inc c.unit. you should also have electrical certificates for work done before and after this date.As posted you need to see if they exist from any of the sceams a lot of these can be checked on line as well as through your local council building control. if there is a name on the sticker of the consumer unit you could contact them however electrical contractors will only hold on to coppies for a fixed length of time.
I agree make decent Sparks very angry, and that's being polite
That should read SHOULD HOLD COPIES
If any work has been notified by an electrician who is a member of the NICEIC can be checked here
NICEIC Online Certification: Notification Check - http://checkmynotification.com/
Only problem is its only NICEIC and elecsa but there are other schemes out there.
Lee couldn't get that NIC web page to function. Wasn't locating on addresses, for notifications (which I know have been recorded). I entered a cert number (Building Regs Compliance), and that wasn't found either.
Have you got it to work? Only mention it 'cos OP might come across the same, and come to the wrong conclusion.
PS They were Elecsa numbers, perhaps they have their own search page?
Cancel that, seems the Elecsa (NIC) web site has technical issues this morning.
Well thanks to everyone who has taken the time to reply.
Here are the photos as promised...
The light fittings are connected to top left and top right terminal.
The cable coming in at the top from the left is the live and neutral.
The cable coming in at 9 o'clock is the ceiling switch.
I believe the cable at 6 o'clock is maybe the redundant switch wire which would have originally fed one of the lights when the bathroom and toilet were separate.
As can be seen, all of the Earth conductors have been snipped and there are no sleeves on any of the black switch wires.
The other photo shows the cable which has the taped up connector and disappears under the loft boards.
Thanks for looking.
Doesn't look good, the cpcs have been cut out which may mean some accessories or fittings are not earthed. I would say that has been like that for years from the look of it.
Reply to Electrical certification for house? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi Everyone, Sorry in advance if this is a silly question. There is a junction box in my mother's kitchen, on the wall above her kitchen...
