Discuss Electronic Equipment and IR testing. What component causes low reading to earth? in the UK Electrical Forum area at ElectriciansForums.net
Insulation resistance testing with electronic equipment between L-N connected together and earth.
Switch mode power supplies have EMC capacitors between L - N - E.
However, when you test for IR you are using DC. Capacitors block DC.
What is there in some electronic equipment that allows a DC current to flow from L-N to earth?
This also happens in RCBOs that have a functional earth tail.
Also, not all switch mode power supplies have EMC capacitors. Plug-in ones have no earth. If they can be made without the earth, and therefore omit the EMC capacitor to earth, why on earth (he he) can't they all be made that way? (I have a feeling the answer to that is that there is provision to omit EMC from small items).
Reply to Electronic Equipment and IR testing. What component causes low reading to earth? in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi Sorry to bring this one up again but have read numerous posts and answers and not got an answer specific to my situation. I have a Loncin...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
