Discuss Emergency Lighting Mains Indication Light in the Lighting Forum area at ElectriciansForums.net
Good morning all,
I have a question about emergency lighting and the requirement of an indicator light stating that it is on mains power and charging.
The centre that I work at has been refurbed and new LED type emergency lights installed at very high level, I don't know what MCB's control them and I noticed that they don't have a L.E.D. indicator showing that they are on mains power.
My question is, do they have to have an indication that they are on mains power and therefore charging? if so where will I find the regulations relating to this?
That's 2 questions,
thank you
Paul
BS5266 states that all lights must conform to BS 60589-2-22.
Part of that Standard is that each emergency luminaire must have a green LED indicating charge status.
This would only apply to self-contained emergency fittings however. Clearly a central battery system would not have a charge indicator at every light fitting.
As said see if you can see them in the dark. Have you done a test with the key switch to see if they come on? I wonder if the batteries have been connected.
I've found a key switch in the wrong position more than once.
Sometimes the LED indicator can be hard to see even a couple of feet above your head if it is not in the holder properly or has a poor light output
Reply to Emergency Lighting Mains Indication Light in the Lighting Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
Hi, RCBO appropriate test facility for emergency lighting? I have a car storage facility ( one corridor with 10 rooms off the corridor to store...
Hi all Got a question regarding HMO compliance. Visited property today for landlord looking to apply for an HMO license for one of their...
