Discuss Emergency lighting regs in the UK Electrical Forum area at ElectriciansForums.net
This is not necessarily correct. The scale of building and footfall may permit a single means of escape.
In general there should normally be at least 2 escape routes but in certain circumstances one is acceptable. One example is if a part of the building only accomadates up to 60 people, there are other points to look at but the fire officer would be able to give more advice. If you are on the first floor or above you would expect two or more and each would be independent from each other.
You stated there must be two means of escape, this is not correct. I am well aware of building requirements.
Sounds to me like several things may be being confused:
Fire exit door - a means to escape the building when there is a fire. Needs appropriate signage, lighting and door handles to help people exit in a hurry. I would have thought the rules don't care if the door is open or not when there is no fire.
Fire door - a door that needs to resist the spread of fire. Often between fire compartments in a building. These need to be closed when there is a fire to do their job. Various ways are used if making sure they are closed in a fire are used like signs saying "keep shut", springs that close the doors, automatic closing doors etc
It sounds to me like the problem may be that it is a fire door and that the way they are ensuring it is closed in a fire is by keeping it locked shut. Are there springs/door closers on the door so that it closes automatically when you do open it?
Whether it be a Fire door, Disabled access, Fire Escape or just a door, it's easily opened in an emergency.
The manager may have other reasons for not wanting the door open, such as security, or maybe It's just to stop the mess that's been left there.
I think the confusion is that whether the door is an emergency exit or not, the issue is that the staff would like the door open for fresh air, the manager says no, and is giving the excuse that it’s a fire door and must remain closed…. And to clarify his position, he’s padlocking it shut.
I asked earlier whether there was adequate ventilation…. If not, it’s an HSE issue.
My 17yo daughter is working at a factory for summer and I just found out there’s only 2 toilets… (1 unisex, 1 disabled) for over 50 staff…. So I might be reading up on HSE more than I should recently.
Reply to Emergency lighting regs in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hello Got a customer who needs certification for a monthly emergency lighting test. What would be the best cert to provide them with? The NICEIC...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
