Discuss EP Bonding Copper pvc copper in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, a little clarity required please.
I’ve recently been to a property to make an emergency repair to a broken cable ( they drilled through it). I’ve patched the cable for the moment but while I was looking at the bonding I found the CH pipes bonded next to the incomer but not the incomer itself. The board doesn’t appear to have earth bond for water either, gas is present and correct. The incomer is copper then it goes to pvc then back to copper. It’s some distance from the CU unfortunately.
Since I spoke to them they got another electrician round and plumber for a second opinion and both say the bonding is acceptable. Am I missing something here? I mainly do commercial stuff and rarely domestic.The house is 1960’s in age.82A87D78-D649-46ED-B26F-2EA60FA28A2F.jpeg
Reply to EP Bonding Copper pvc copper in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
One of the oddest jobs I've ever had today. Called by a plumber I know who had attended after a leak through the kitchen ceiling from bathroom...
6K
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
I’ve been asked to add a couple of extra points to the single ring main in a flat. Building fabric is concrete, all of the electrical installation...
4K
N
Hey all, Just a quick query. If the main incoming water to a property is copper and the consumers side has a mixture of copper and PVC, is...
Been to a job today to replace a faulty immersion thermostat. The existing spur supplying it was broken and about 30 years old so I replaced that...
6K
