never said i was using 10mm, that is what a part p 'sparky' aka greedy plumber, playing out of his field undercutting others has stated should be used to the client who is in need of a good hiding if they want advice on electrics from a plumber... dont wish to start a riot just trying to consolidate on regs and ideas to point my finger at when questioned why it should cost more...some people seem to feel that 'less' is more.
2. Do you want to extend the equipotential zone or make outbuilding stand alone TT. I personally would more than likely extend zone as its TN S and install EMT in outbuilding.
Had this situation on a recently completed job, when DNO upgraded main fuse too 100A he said a spike will be needed for the outhouse, said it didn't matter if EMT was installed or not, regs said fault current couldn't pass through existing build (about 40m away) though he couldn't tell me which reg and my employer reckoned EMT would've been more than the earth electrode.
still never found why, in a book anyway.
Any ideas ?
This whole scenario just beggars believe!! I can't make up my mind who's worse, the plumber or the OP...
I'm staying out of this for the time being, at the moment your all on a hiding to nothing!! lol!!
Any ideas ?
Whoever told you that, (and it was probably the meter guy) was talking out of his arse, total load of nonsense!!
it beggars belief that you can insult people who have genuine questions from scenarios in the real world and still not provide justification. Not all of us have had the opportunities others may have.
Any ideas ?
That DNO guy obviously knows something more than I do. Perhaps I have got it wrong for all these years believing electricity takes the path of least resistance. :)
Sintra,
Thankyou!
so, TN-S + EMT means fault path is comparatively low to that of a TT plus no soil integrity to allow for.
am I right to believe there is no specific reg for this instance just that the fault path is preferable to be as low as possible to meet ADS?
RCDs are beautiful things.
Kind regards
There is a simple answer to that statement then isn't there, if your not capable of getting even the basics straight, then you shouldn't be taking on that work in the first place!!
One of the most farcical threads ever.......is the OP having a giraffe or what?
Two 10mmT/E's?.....whats the plumber going to do,put everything on a 60a ring?
The whole things a wind-up IMHO.
I'd still like to know what spur unit can handle a 10mm2 condutor, until thats answered I cannot get to the next part, really baffled by that one I'm afraid, a spur???????????? WTF
just unbeleivable that twin and earth is even being considered for the outside environment knowing that ducts are often permanently filled with water !
personally, i'd nip to b&q and buy 2 40m extension leads. make sure they're fully unwound when using heaters.
:34:
