B
brightspark2010
Evening all I was just wondering if anyone can tell me the procedure or a good method for extending a ring main wire in singles the trunking the conduit comes from is innaccessible due to height so I need to thru crimp at outlet one set L,N AND E and connect the other only problem is how can i find out which set of the original cables is a set as is wired in singles throughout. any advice CHEERS!
if you had a fuse finder you could easily id the cables, Kewtechnic do one, or a tone generator that you normally use for phone lines
Disconnect and separate the wires at the socket and CU..........you will then be able to ID a set at the socket by continuity testing between the CU wires and socket wires.
Im guessing your got 6 singles coming out one tube try finding a socket thats on the same circuit as close to the one your working on and use a wander lead from that socket. the 3 with the lowest readings would be one set the 3 with the higest readings would be the other set, L and N should read the same and the E slightly higher.
(This method aint fool proof so you will need to interpret the readings you get)
