Search for tools and product advice,
Discuss Extractor Fan - No Rcd in the UK Electrical Forum area at ElectriciansForums.net
G
GaryWall
I just realised that I have a ip45 rated extractor fan in my ensuite, located on the ceiling above the shower, that has no rcd protection. It is controlled via a 3 way switch, that also controls downlights and a light above a cabinet. Should I be worried? Is it safe? How urgently should I get a rcd fitted by an electrician? Thanks.
the chance of you putting you pinkies in it whilst in the shower is rare , unless of course you have the mental capacity of a plumber.
Ok - thanks.
Is that the reason why an rcd exists?
Please don't laugh, but I thought that it was possibly because the condensation from the shower could rise and get inside the wiring of the fan, and cause a shock while standing on the shower. Is that just stupid? I'm a complete diy'er.
Check you zones in the regs for any requirements.
Have you installed it or has someone done it for you???
A little more info will help to provide a qualified reply.
Why do you mention IP45?
I moved into the house fairly recently, fan was in place. I've looked up the fan online and it's ip45 rated, as long as a rcd is fitted. I've an old fuse box, no rcd as far as I can see. And no rcd near bathroom.
if the fan were being fitted today, the reg's and the manufacturers instructions specify RCD protection, but they're not retrospective. a fan rated IP44 or higher is specced as suitable for fitting above a shower/bath in zone 1. my advice would be that it's safe to use ( as in thousands of homes with earlier installations) but for peace of mind, i'd consider upgrading the old fuse board to a modern board fitted with RCD protection, either a dual RCD board or one with RCBOs. if you post your location, one of us may be close enough to give you a quote.
Reply to Extractor Fan - No Rcd in the UK Electrical Forum area at ElectriciansForums.net
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
