Discuss Extractor fan to timer type in the UK Electrical Forum area at ElectriciansForums.net
Hi
I’m thinking of changing an extractor fan (in a WC) to one with a run on/timer. The current set up doesn’t have an isolator, and wiring runs from the light bulb to the fan, which is sited in the ceiling about 18” away. The fan is vented through a flat roof above.
Now, I realise that i’ll need a permanent live and to fit an isolator switch. I’m thinking of doing this:
- to leave existing wiring as is, and take a live feed from a lighting circuit junction box in the attic;
- to install an isolator switch in the permanent feed run, ie in the attic.
I’d rather not have to channel into walls to run a new 3 core cable.
Hi
Sound like a rubbish plan.
Do you not think it would be a good idea to isolate the 'switch live' and 'neutral' as well?
or give this guy a job.
49903
Hi - just so you know - new regulations from January mean that changing the wiring on a circuit with lights will require an RCD be fitted, if it’s not already. And depending on details, a building works notification (Part P) might also be required as you are doing electrical work in a bathroom. An Electrician can help you with both of these aspects, as well as testing the completed works are safe, just saying :) .
That really doesn't sound good at all Daljit, also dangerous because:
1. You could be taking the permanent live (PL) from a different circuit.
2. You will only be isolating the PL not the switch live, so if you do use the isolator switch (i use the term lightly) you would still have a live fan when the light switch was on. Someone who moves in after you could well get an electric shock as they would never suspect that it had been wired so badly.
I realise you are probably trying to safe some money but you really should get an electrician to do this work.
Hi, WC so no special regs
Thanks for considered comment! It’s less about saving cash, it is a simple job but just don’t like the idea of channelling into walls.
It’s a WC
Surely anyone looking to service the fan will know it only operates when the light is switched on...
Hi mate. The fan will require a 'permanent live' as well as a 'switch live'. Both will need isolation, as well as the 'neutral'.
Have a look at the manual for the fan you are thinking of getting. This should tell you how to wired it.
What fan are you thinking of getting?
Reply to Extractor fan to timer type in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
